Diff pinion removal
ross_jsy
Post Thu May 21, 2015 2:33 pm
Stripping a diff down and am about to remove the pinion gear. Have undone the nut on the end. Just to confirm before I throw it in the press and ruin it, it just presses out right?
Ross
ross_jsy
Post Thu May 21, 2015 4:17 pm
Well it presses out in case anyone is looking for the answer in the future
Gert_8
Post Thu May 21, 2015 4:23 pm
Hahaha. Answered your own question. Good man! :D
ross_jsy
Post Thu May 21, 2015 4:38 pm
After looking at it a while, figured there was nothing that could be holding it in so chucked it in the press and crossed my fingers. Luckily nothing broke and it's now all stripped, ready to be cleaned and 2 packed
Gert_8
Post Thu May 21, 2015 4:39 pm
Good job! :D
Demlotcrew
Post Fri May 22, 2015 11:02 am
Oh no :(
ross_jsy
Post Fri May 22, 2015 11:15 am
What's the matter Andrew?
Demlotcrew
Post Fri May 22, 2015 11:39 am
I didn't know your plans were to renew the bearings, I thought you wanted to paint the casing only.
ross_jsy
Post Fri May 22, 2015 5:00 pm
Built it back up and blasted the case. Came out pretty well, but the bead blaster I was using was shite. Going to take it back on Tuesday and finish it off
Is it too homo to fill and sand the pitting?
