m10 318i donks have two variants ?
Post Sun May 17, 2015 12:02 am
this is only my 2nd m10 donkey so please forgive my ignorance :wink:
my first m10 318i had a crank driven distributor ...on a b reg , this ones a c reg and wtf did they do here with the dizzy , it looks laughable but there should be a reason for it ?
anyone shed some light on this particular donk , there was only 1 m40 after all ....thank f00k.
[/img]
Post Sun May 17, 2015 9:44 am
Thats the most common E30 setup
Post Sun May 17, 2015 9:54 am
IIRC, at some point in the M10's life, the direction of rotation of the distributor was reversed.
Post Sun May 17, 2015 11:03 am
Brianmoooore wrote:IIRC, at some point in the M10's life, the direction of rotation of the distributor was reversed.
All M10 E30s were the same. The change was in 1980 when the E21 316 went from 1600 to 1800 cc. They changed to electronic ignition at the same time .
Post Sun May 17, 2015 11:14 am
I'm fairly sure all M10 E30's had the same donk,
my first turd was an 86' 316 (the 318i was out of reach)
how i longed for an Injection instead of the Pierburg drama's and 15mpg :( they were all were blessed with 1800cc's
Incidentally Mick my first E30 was a 2 door in Zinnobar red with keep fit windows, reg was C256JBR (may have been C257JBR) not far of the production line from the turd your breaking !
Post Sun May 17, 2015 2:00 pm
All E30s were factory fitted with the later version, but plenty of cars will have had replacement engines.
