I have done much searching on this topic and not really found an answer.
Has anyone achieved a factory look for the rocker cover and intake manifold?
I wish to keep the car as original as possible and was considering sand blasting or similar but have no idea what the finish would be?
All help appreciated.
Original rocker cover and intake manifold finish
Gavia is your man.. drop him a PM.
- Cypriotgeeza
Not sure what finish you are going for but i think the rocker covers were an unpainted metal finish originally
This is how i did mine and i think it looks pretty factory in the bay
Check my M30 build threads:
i think as above they were originaly metal finish but had that wax stuff sprayed all over the bay from factory, if you just blast it then it will quickly start corroding/oxidising with the white flaky stuff with the heat and just wont last (looked in to it myself recently)
so just had some done myself at the body shop, dipped, aqua blasted, then painted and lacquered and baked, i replaced some that i had powder coated last year but it marked quite easily and was never happy with it
they look good
they look good
e30Passion
Cloggy Saint
minesapint
