Anybody interested in having Hartge caps repaired?
appletree
Post Fri Apr 03, 2015 8:16 pm
I have looked into this before and have now got a design/method that I'm happy with so depending on if others are interested I could possibly offer repairing these caps for around £15 depending on how much interest there is and what the materials end up costing.
The repair uses a bought in centre cap, as the old design used material that wasn't flexible enough, and then a specially machined insert to hold the cap in place.
Here are some pictures which will explain it better.
Old tabs are machined off to keep a nice flat surface and a new cap glued and bolted in place for added security. Under the Hartge sticker the cap is hollow so a counter sunk bolt will fit with minimal modification.
An insert is turned up to sit inside the old clip groove and is gapped like a piston ring to fit tight in the bore.
Fitted, nice and central just like and original.
They fit with a very reassuring clunk as they lock in.
I would need to have your centre cap to put it in the lathe to make sure the hole and clip are fitted centrally and then post the cap back with the insert.
If you are interested post up how many you would be interested in, once I get an idea I of interest i can get some firm prices and go from there.
Also if you have any spare caps with missing clips you don't want anymore i'm after two my self so PM me as i would be interested in buying them.
Thanks Matt
anothere21323i
Post Sat Apr 04, 2015 10:39 am
Well done - this looks like a great solution to an irritating (and common) problem. good work :D
Demlotcrew
Post Sun Apr 05, 2015 11:37 am
On track I got my wheels so hot the caps melted in place a˜¤
appletree
Post Sun Apr 05, 2015 3:49 pm
Demlotcrew wrote:On track I got my wheels so hot the caps melted in place a˜¤
Bloody hell! was that on a track that was heavy on brakes then?
SAP1
Post Thu Mar 11, 2021 7:14 pm
Thread bump!!! Are you still doing these?
rix313
Post Fri Mar 12, 2021 10:15 am
God loves a thread revival
Post Fri Mar 12, 2021 1:29 pm
Especially the Hartge god
Kedge
Post Wed Mar 17, 2021 7:56 am
I've got quite a few caps knocking around with missing tabs, would be good to get them safe to use again.
Instagram - Kedge85
