How would you tell if you had an LSD?
BROOMY
- busy saving Clifford
Does the tag have an S on it ?
Or some other way of telling.
11's ees ;)
like a boss !
like a boss !
+ a yard full of scrap turds
reggid
skidz
E30 325is with M20B31
e30Passion
Put one rearwheel in the mud, sand or on ice while the other is on asphalt. Without an lsd you'll be standing there spinning the wheel with the least grip when you smash the throttle. Or as said try a good burnout
BenHar
The tag on the diff should have an S at the start of the ratio.
Or jack the rear up so both wheels are off the ground. Hand brake off and in neutral. turn one of the wheels by hand. If the other wheel turns in the same direction it's an LSD. If it turns in the opposite direction it's an open diff.
Ben
Ben
Better still, jack up one side of the car ,and assuming the brakes are not sticking, try and rotate the lifted wheel, if it does not turn, you have a LSD. The tag should be used as a guide at best. At 25 + years of age, lots of rear covers / tags have been swapped around.
- E30 Zone Meets/Events Team
Ask the expert, eh Pete...pacerpete wrote:Better still, jack up one side of the car ,and assuming the brakes are not sticking, try and rotate the lifted wheel, if it does not turn, you have a LSD. The tag should be used as a guide at best. At 25 + years of age, lots of rear covers / tags have been swapped around.
I watched Pete check to see if one of his cars had an LSD once, not a pretty sight.
Rav335uk wrote:Ask the expert, eh Pete...pacerpete wrote:Better still, jack up one side of the car ,and assuming the brakes are not sticking, try and rotate the lifted wheel, if it does not turn, you have a LSD. The tag should be used as a guide at best. At 25 + years of age, lots of rear covers / tags have been swapped around.![]()
The poorly 3.25 pumpkin is now with a known motorsport aficionado and is being fully freshened up and uprated to 40 % . The one tyre fire will be a thing of the past
That was very funny that day,Rav335uk wrote: I watched Pete check to see if one of his cars had an LSD once, not a pretty sight.
He's certainly a much nicer person when he discovers a £200 turd has one fitted
Should have video'd it that day..e30topless wrote:That was very funny that day,Rav335uk wrote: I watched Pete check to see if one of his cars had an LSD once, not a pretty sight.![]()
BenHar
Trouble with that is it could just be the hand brake stuck on.pacerpete wrote:Better still, jack up one side of the car ,and assuming the brakes are not sticking, try and rotate the lifted wheel, if it does not turn, you have a LSD.
If you jack it up so that both wheels are up you can illiminate that error.
Ben
87mtech27
magpie wrote:11's ees ;)
like a boss !
Love it!!
BenHar wrote:Trouble with that is it could just be the hand brake stuck on.pacerpete wrote:Better still, jack up one side of the car ,and assuming the brakes are not sticking, try and rotate the lifted wheel, if it does not turn, you have a LSD.
Ben
That is why I specified that you need to ascertain that your brakes are not dragging. Obviously if your handbrake / brake was sticking on so much that you could not turn the wheel, you would probably know about it !
