pigeon poop
theretroking
Post Mon Mar 16, 2015 11:18 pm
this morning had to clear some pigeon poop of my car.
carefully removed it with warm water, unfortunately its left a white haze on the roof about 2 inches in diameter, any idea's whats the best way to get rid of it.
Gavla
Post Mon Mar 16, 2015 11:50 pm
Unfortunately it is like acid...I usualy use a water based degreaser with a cotton wool pad. You could try washing up soap...soak the cotton wool pad and leave it on for a few minutes.
Alternatively and better...get some polish and a microfibre pad from Halfrauds...something like Farecla G3.
HairyScreech
Post Tue Mar 17, 2015 5:12 pm
Meguires do an "ultimate compound" which I have found to be very good for this sort of thing if used by HAND.
http://www.meguiars.co.uk/product/200/U ... -Compound/
theretroking
Post Tue Mar 17, 2015 7:56 pm
HairyScreech wrote:Meguires do an "ultimate compound" which I have found to be very good for this sort of thing if used by HAND.
Sounds perfect, last time i used t cut and wasnt very happy with the after effect.
zd3bx
Post Tue Mar 17, 2015 8:16 pm
T-cut is good enough, you just have to wax the surface after, because normally T-cut leaves a bit of a matt finish.
RetroAde
Post Tue Mar 17, 2015 10:22 pm
Run a clay over it, it lifts out all organic contaminants and is kinder on the paint. If that still leaves a shadow hand polish the area with something like Farecla G3.
Worst thing I've seen on paint is cheap suntan lotion, do not get it on your car.
