Could someone please advise what clio servo I should buy, a link would be good.
Also some fitting instructions would be handy.
Thanks!
Clio Servo
ross_jsy
Plastic winged Clio. Loads in scrap yards.
Fitting is easy. Remove old one and replace, then make a spacer to fit inside the master cylinder. Start off around 10mm and adjust to suit
Grrrmachine
- E30 Zone Wiki / Team Member
Nice new one here - http://www.ebay.co.uk/itm/Renault-Clio- ... 3ceadb301d
Muzz2676
Cheers chaps, will have a go at my first mod
You will need a 20mm spacer for that servo
Muzz2676
How do i get one of those?DanThe wrote:You will need a 20mm spacer for that servo
Bristol_Jer
I found I had to slightly drill out the hole going through the fork on the servo arm to allow the pin to go through, not sure if all the clio servos are like that though.
Bristol_Jer
You need to make one, have a look at the wiki link posted aboveMuzz2676 wrote:How do i get one of those?DanThe wrote:You will need a 20mm spacer for that servo
Yes the pushrod hole needs opening up to 10mm
