engine swap legalities
I've got a feb 1993 registered 318 cab with a catalyst, I may have the chance of buying a 1989 325 as a donor for the running gear, the plan would be to completely refurbish and fit as factory.
Is it possible to do this legally given my cars post 93 and needs catalyst testing for the mot?
I'd prefer to do it properly and change the log book, will this cause further complications?
- Contact:
Im sure the tester has to test for whichever is the oldest, therefore they would test with the earlier rules/pre cat as your engine is older. If your buying the car just keep the reg doc and take it with you for MOT to prove the age of the engine.
There is no requirement to change your reg document, and just because you have doesnt mean the conversion is 'done properly'
Gert_8
- Location: In your back passage faster than a rat up a drainpipe!
And don't forget to inform your insurer...!
Gert_8
I was only pulling your leg, but it's surprising how many would make a change and not advise the insurer.
As Dan says, the emissions test will be carried out to whichever is oldest so as the engine is pre-cat test, a pre-cat test is what you should get. But, the testers around my way are now getting hot on wanting proof of engine age (if you say its older than the car) and it's down to whoever is presenting the car for mot to prove, so keep a copy of the donor V5 and take it with you (as long as the engine number matches).
As for informing the dvla, I personally wouldn't bother as it can bring more hassle than is needed. The dvla will only be interested if the change of engine cc moves the car into a different tax bracket, which it won't with an E30.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
- Kos
- Contact:
One for Jamie I think
www.pukardesigns.com
IG Pukar.Designs
IG Pukar.Designs
- Contact:
Not exactly the best reasoning for causing yourself a potential load of hassle, if the DVLA want to inspect your car you wont be getting the V5 back anytime soonstew72 wrote:
I've got a feeling that at some point engine swaps not declared on v5 may become an issue, hence wanting to changethe v5 if practical.
It is not the law to inform the DVLA of an engine change unless for reasons that James has stated
Seems every time you click an ebay add for a "325" for it then to go on saying it started life as a 316 , and it's still registered as a 316 and up to you ...Gert_8 wrote:I was only pulling your leg, but it's surprising how many would make a change and not advise the insurer.
- Brianmoooore
If it was born a 316i, it is still a 316i and will always be a 316i. This is the model name, that happened also to be closely related to the engine size of BMWs at the time, but is still a model name, such as Corsa, Panda, etc.
It may now be a 316i with a 2.5 litre engine, but it's still a 316i.
- Brianmoooore
Problem of proving engine age only occurs if you fit an engine such as an M20, that was fitted as standard in another E30. If you go for an engine such as jmc330i's M44, a M42 in a touring, or a M5x then these are all tested to the pre cat. limits, even if both engine and E30 are post 08/1991
HairyScreech
^^ How so? Is there a non-standard to car loop hole I am not aware of?
If the combination of car and engine was not offered by the manufacture, so E30 with 24v or V8 conversion, E30 touring with M42 or M44 etc etc, then the emission test is to be carried out to the pre-cat limits as long as the car was first used before Aug 1995.
Vehicles first used between Aug '95 and Aug 2002 have slightly different rules.
http://www.motinfo.gov.uk/htdocs/m4s07000309.htm
That's how my '93 touring with '99 M44 engine is MOTd with a pre-cat test
I won't say it was easy trying to teach the tester his job though
James
'91 325i Sport
'91 325i Sport
- Brianmoooore
Lines three and four of note 2 can be used to advantage if necessary.
Good point although I'd expect most mot testers to take this route if they can't find the engine details in 30 secondsBrianmoooore wrote:Lines three and four of note 2 can be used to advantage if necessary.
