Brake bleeder, anygood?
Post Thu Jan 08, 2015 8:22 pm
http://www.ebay.co.uk/itm/Sealey-VS020- ... 1c49ff924b
Anyone used these? Looks like it could make life alot easier than someone helping pumping the pedal or the other systems that work off the resevior?
I've got a compressor air line, this would be ok on say e30,e34,e36 and maybe e46?
Andyboy
Alpina Colada
Post Thu Jan 08, 2015 8:39 pm
Gunsons easibleed, 20 quid from Halfords. Job done!
BROOMY
busy saving Clifford
Post Thu Jan 08, 2015 8:42 pm
sorry I biught Sumin else for a fiver.
You still need 1 man.
http://www.halfords.com/webapp/wcs/stor ... reId=10001
Post Thu Jan 08, 2015 8:55 pm
Andy that one i linked is only £21
ricey46
Post Thu Jan 08, 2015 9:04 pm
I'd go for the Easibleed every time, so easy to use, just mind and screw the cap onto the reservior tightly or it goes everywhere :D
Paul.
325i sport Tech1
335i Chromie - Sold
2001 E46 M3-Sold
1999 E39 M5
ricey46
Post Thu Jan 08, 2015 9:06 pm
Paul.
325i sport Tech1
335i Chromie - Sold
2001 E46 M3-Sold
1999 E39 M5
hennared323i
Post Thu Jan 08, 2015 9:10 pm
Simon13 wrote:http://www.ebay.co.uk/itm/Sealey-VS020- ... 1c49ff924b
Brilliant if you have the pressure and air supply from your compressor
maxfield
the easibleeds are just a valve, so you have to keep pumping the pedal, then checking fluid etc.
The one Simon linked just pulls a vacuum so you haven't got to keep jumping in and out the car. I used to have one, made it loads easier to do a brake fluid change. Especially working on a 2 post ramp getting in and out.
bigbird76
Post Thu Jan 08, 2015 9:14 pm
Had an ezibleed for years and served me well
This one would do the job i have one and its only £3.38 delivered and you dont need an airline and its a one man job also.
http://www.ebay.co.uk/itm/Vizibleed-ONE ... 3a73501d48
Andyboy
Alpina Colada
Post Thu Jan 08, 2015 9:43 pm
maxfield wrote:the easibleeds are just a valve, so you have to keep pumping the pedal, then checking fluid etc.
I don't pump the pedal. It's pressure on the master cyl reservoir - just open a bleed nipple and out it comes. That's the whole idea of it!
vytas85
Post Thu Jan 08, 2015 9:59 pm
http://www.ebay.co.uk/itm/Gunson-EEZIBL ... 1e71d94200
gunson eezibleed working very well,just plug on your wheel tyre.
maxfield
Post Thu Jan 08, 2015 10:05 pm
My bad, I had an 'easibleed' all it was, was a bottle with a 1 way valve in that just stopped air going back in, you had to pump the pedal.
Each to there own, I always found it effortless with my vacuum pump.
Jesus325iTouring
Frog freak !
Frog freak !
Post Thu Jan 08, 2015 11:39 pm
Andyboy wrote:Gunsons easibleed, 20 quid from Halfords. Job done!
Gets my vote too, never had one before, but bought one to bleed up the clutch on my Touring, excellent bit of kit.
HairyScreech
Post Fri Jan 09, 2015 1:44 pm
Used an eze bleed the other day for the first time as all the lines were new and dry. Actually worked really well.
Had to give them a little pump/manual bleed just to get the last of the air out of the calipers but that was all, very little hassle.
Green
Post Fri Jan 09, 2015 5:15 pm
I bought an easybleed couple of years back, so good for working on your own. Just screw into reservoir, connect to tyre, open nipple until bled. Takes like 10 seconds a corner.
Kedge
Post Fri Jan 09, 2015 6:32 pm
Another thumbs up for the Eezibleed. Was having a nightmare bleeding my full WMS kit with help, Eezibleed had it done in a matter of minutes on my own, wish I'd bought one years ago!
Instagram - Kedge85
milescook
Post Fri Jan 09, 2015 8:17 pm
bigbird76 wrote:Had an ezibleed for years and served me well
I've got this one too it's pretty simple - even I can manage it! :D I bought one of these previously
http://www.demon-tweeks.co.uk/motorspor ... action-kit
Snapped a bit of plastic, they sent me a replacement and it's still never been used.... might stick it up for sale actually to fund the car repair! :D
Also please help the race budget by watching some videos :) https://www.youtube.com/cookracinguk
milescook
Post Fri Jan 09, 2015 8:20 pm
Also, one way speed bleeders are pretty good kit too. Have them on my front calipers so in theory I don't even need a one way valve, just turn 1/4 turn attach some tubing and pump brakes into the bottle of fluid.
powelly
Post Fri Jan 09, 2015 8:37 pm
It'll be just the job bert, do you remember the pressure bleeder I used on Nics Z3 many moons ago, they are even better, fair bit more money though.
Image Le Mans Classic 2006
Post Sat Jan 10, 2015 7:08 am
Another one for eezibleed here. Had mine for years and it served me well. Used it only last week on a Caliper replacement. Simples
RobWill116
Post Sat Jan 10, 2015 9:57 am
Another one for eezibleed, simple piece of kit but works perfect every time without the need for any help.
sh123
Post Sun Jan 11, 2015 10:51 pm
We have one of the vacuum ones at work, its a snapon we have and its utter shait in kind words, we've never been able to get it to work. but we have a pressure bleeder, one you pump up at the resevoir and thats brilliant! not sure on make though.
Post Sun Jan 11, 2015 10:57 pm
I'm another one that gets on well with the Gunsons kit. Normally, I don't even bother with the bottle - I just fill the reservoir to the start before I start, and connect the appropriate Gunsons cap straight to the workshop air line via a pressure reducer turned right down to 3 - 4 psi.
Demlotcrew
Post Fri Jan 16, 2015 11:41 am
I use this........ 8)
Old F1 unit, absolute porn! The two 5l Ti tanks inside are especially erotic.
ajay
Post Fri Jan 16, 2015 12:07 pm
I thought my £100 pressurised bleeder bottle was cool till i see that thinga‘†... Probrably cost more than most the turdz brakes that have the pleasure of being fluid changed by it...a˜Ž
SHAKEELE30
Boost Junkie
Post Fri Jan 16, 2015 12:38 pm
I prefer andrews piece of kit!
winkeye
Dont know what it is or how it works but it sure as hell looks alot better!
Demlotcrew
Post Fri Jan 16, 2015 12:51 pm
Its an old F1 bleeder, it basically drains and drys the brake system, then pumps in new fresh fluid. Its pretty neat as it does both sides of multi piston callipers as well as front and rear circuits at the same time, makes bleeding a joy! No messing, all dry break fittings (calliper dependant).
Heres a better photo.
Andrew
Post Fri Jan 16, 2015 1:18 pm
sh123 wrote:We have one of the vacuum ones at work, its a snapon we have and its utter shait in kind words, we've never been able to get it to work. but we have a pressure bleeder, one you pump up at the resevoir and thats brilliant! not sure on make though.
Like this?
Ive been using the same one as that for over 15 years now without a problem
nickso
Post Fri Jan 16, 2015 3:47 pm
I have the Eezibleed too and it works well but might buy that one in Simons link as it will work well on the bikes. Bike brakes can be a right cunt to bleed from dry. :-x
'88 e30 328i M52 track bint.
Jon_Bmw
Dangerous when thinking
Post Fri Jan 16, 2015 4:44 pm
Andrew that thing is ridiculous. :cool:
You must have been waiting for years for someone to post up about brake bleeding equipment so that you could post that photo! haha.
Demlotcrew
Post Fri Jan 16, 2015 8:21 pm
:chuckle: To be honest, someone alerted me to the thread and said, you should put up some photos of that crazy bleeder you have :o:
It's good as it shows that vacuum type bleeders are very much ok!
Post Fri Jan 16, 2015 8:30 pm
I have an electric pressure bleeder which runs at about 1-3 bar depending on what you set it to. It's identical to one used in BMW dealers and a pressure one is what's required to bleed DSC units on later stuff and they are often being replaced or repaired on modern turds.
Post Fri Jan 16, 2015 8:33 pm
I'll take a pic tomorrow but it's no where near as impressive a Andrews bit of kit!
Demlotcrew
Post Sat Jan 17, 2015 12:26 am
Same here Baz, regulated pressure and vacuum, instructions say to run it at 50psi.
Vacuum at 27"Hg
I think that 50psi of pressure is a little high for our older cars where the reservoir is not locked down.
