Antifreeze
theretroking
theres blue, pink and green what is recommended for an E30 and what is the difference between the colours.
jmc330i
Green iirc - I'm sure the BMW antifreeze I used was green. It's not just antifreeze, it's also a corrosion inhibitor.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
DHFiS
There has been some really heated debate about this subject in the past.
I use blue.
I use blue.
DHFiS
Here you go, 5 pages of detailed discussion about antifreeze
http://www.e30zone.net/modules.php?name ... 20&start=0
theretroking
bigbird76
I use Comma G48 thats the green one that jmc330i mentoned.
But really up to you i suppose pink or blue is ok for general use but do not mix them.
Leigh
Leigh
BHadley
Red is more modern stuff, green or blue is the stuff. I too use the comma blue (bottle label is green)
German-Whips
Is it fine to mix 2 different BLUE brands of antifreeze when topping up the levels?
Shouldn't pose an issue as long as they're both blue right?
HairyScreech
Good solid blue glycol based coolant for all BMWs pre 95.
