Tyres
- Kos
- Contact:
The OEM Size of 205/55 has a few more options today compared to a a couple of years back as this is a standard size on one of the new audis
So, what you fit depends on your budget.
Uniroyal rainsport 3 is a seriously good performer and at £63 is a good price
www.pukardesigns.com
IG Pukar.Designs
IG Pukar.Designs
- Kos
- Contact:
The top end brands arepony wrote:What are the main tyre brands that make this size ?
Continental premium contact 2
Dunlop fast response SP
good year efficient grip
Yoko s drive
Bridgestone protenza RE02
Then you have your midrange
Falken
Toyo
UniRoyal
Hankook
Avon
Fulda
federal
Uniroyal would be my choice
The rest that are available are budget crap
They would be KU31's, I may be wrong but they went out of production couple of years ago and were superseded by KU39's which are not available in 205/55r15polsta wrote:Put a set of kumho ecsta sport on mine last spring, found them to be great no issues at all ,,it's never driven in rain
If you do find them then it's quite probably they have been sitting on the shelf for at least couple of years. If they've been stored correctly they will be fine.
IG Pukar.Designs
IG Pukar.Designs
I just went from a set of crap anonymous budgets to a set of Goodyear efficient grips.. Braking is better in the rain I'll admit.. but drivability I've not noticed any difference whatsoever!Kos wrote:The top end brands arepony wrote:What are the main tyre brands that make this size ?
Yoko s drive
Falken
Toyo
UniRoyal
Hankook
Avon
Fulda
federal
I run yokohama advan and will be upgrading them to either parada spec-2 or vred sportrack 5 in march. The advan are good tyres but you got to pump the rears up higher than fronts to get the best out of them. I use 15" toyo proxis t1r for track and sprint days. They are good but lacking in the wet. Uniroyal rainsport 2 was the best wet tyre I tested. Also noticed that 14's pumped up to 35 psi allow faster and more stable drive and turn in wet weather but worse braking. 16' have the best braking and all round stability. So I run those on my daily wheels now.
Gert_8
- Location: In your back passage faster than a rat up a drainpipe!
Who's selling at that price, please, Kos?Kos wrote:The OEM Size of 205/55 has a few more options today compared to a a couple of years back as this is a standard size on one of the new audis
- Brianmoooore
http://www.oponeo.co.uk/tyre-finder/s=1 ... 205-55-r15Gert_8 wrote:Who's selling at that price, please, Kos?Kos wrote: Uniroyal rainsport 3 is a seriously good performer and at £63 is a good price
Gert_8
Thanks Brian!!
I was contemplating toyo proxies @ £226 for a set of four for my cab - it doesn't see rain. These are the cheapest mid-range tyres I have found that I'd be happy to use.
With the mileage the cab does, the tyres would need replacing through age rather than wear.
+1 for the uniroyal rainsport's
I have run rainsport 2's on my e30 for 3years, they are on my main 'daily' wheels and have seen best part of 15k miles still have loads of tread left, handle reliably and give plenty of grip in wet conditions.
- Kos
- Contact:
Slightly cheaper on camskillsGert_8 wrote:Thanks Brian!!
As for getting knackered with age, you should be alright depending how your stores them/the car
Should be fine for at least 5 years probably longer
IG Pukar.Designs
IG Pukar.Designs
