removing rear seats 2 door
matt86
Post Sat Dec 27, 2014 12:24 pm
Hi how do i remove the rear seats on a 2 door. Is it the 18mm bolts that hold the seatbelts in place. The lower part I've removed. Its just the upright part of back seat left. Thanks
maggspower
Turbo Farmer Tractor Driver
Post Sat Dec 27, 2014 12:29 pm
Hello there Matt
There are 2 10mm bolts, in the corners that are on a piece of flat rod about 10x100mm, then lift up and out.
matt86
Post Sat Dec 27, 2014 1:19 pm
Sorted now, its on a coupe they were hiding under the rear door cards it was a 12mm bolt on each side. It confused me because i couldn't see them until i folded the vinyl at the edge of the door card back. Convertible ones are a lot more straight forward.
cheers matt
Post Sat Dec 27, 2014 1:28 pm
Be sure to get the side cards off and take plenty of pics ! :)
matt86
Post Sat Dec 27, 2014 11:58 pm
maggspower wrote:Hello there Matt
thanks Byron, hope you are keeping well, long time no speak. :)
Post Sun Dec 28, 2014 12:07 am
pacerpete wrote:Be sure to get the side cards off and take plenty of pics ! :)
bosh!
maggspower
Post Sun Dec 28, 2014 12:46 pm
Yes good thanks Matt, hope you are too.
Its very strange isn't it, people rarely have just one e30, they usually come back for more :D
