Few things I need to plan
BROOMY
- busy saving Clifford
I need to change a few items for it to pass an SVA test.
I'm just gonna list them and can you tell me your opinion on the best/easiest way.
Power steering fluid
Clutch fluid
Diff fluid
Brake fluid
Coolant flush
Any help appreciated thanks [/u]
Clutch fluid
Diff fluid
Brake fluid
Coolant flush
BHadley
Hang on..
... I listed these as service items to endure smooth running don't think any of it is relevent to the damage your last post said
BHadley
No worries
Mitchen
Check the wiki..
http://www.e30zone.net/e30zonewiki/inde ... :Servicing
Or google Bentley manual bmw e30 and download the manual.. that'll tell you everything.
What mods. have you done to this E30 for it to require a SVA test?
SVA's all about things like what angle you can see the indicators from, and the minimum radius on the knobs of the switches, etc., not about servicing the engine.
Mitchen
I think he wrote the car off, bent subframe, re previous thread. I'm guessing the service is unrelated to the test
Why would you need a SVA after repairs? Only thing I've ever done is take a Cat C for a VIC test, and I think that is, or is about to be, abolished.
BROOMY
That's it a VIC test.
I couldn't remember the name
Needs nothing for a VIC, other than the VIN on the scuttle not to show obvious marks of having been welded in. It's purely an identity check, and nothing to do with the standard of the repairs.
Doesn't even need to be repaired, other than it needs to be able to move under its own power.
Last one I sent in wasn't even the colour shown on the V5.
The non functioning alarm may be an issue.........
BROOMY
Does it need to be MOT passable?
Been sitting for around 10 years except the repairing of the subframe and the head took off it has no other repairs so I'm wondering if things like bushes need to be changed before the VIC check.
SVA .... VIC...
<< big similarities ,an easy mistake to make
+ a yard full of scrap turds
BROOMY
I'm booking IT tomorrow then.
