M42 engine service
BROOMY
busy saving Clifford
Post Wed Dec 10, 2014 9:10 pm
What kinda service would you say to do to a M42 engine?
Done air filter , was gonna do the oil but have a feeling we renewed that when we ripped it apart.
Renewed injectors not long ago
Would you say things like oil filter,fuel filter.
Usually ide say valves but as you know they're hydraulic .
I'm gonna start doing this car as lately I been lazy.
Also what's a SVA test rules regarding the car as this was previously written off because a side impact .
Now it's all been sorted bar the paint which is wrong colour .
BHadley
Post Wed Dec 10, 2014 10:56 pm
Depends what history you have of what was changed and when.
Basics would be ,
Oil and filter change
Air filter change
Fuel filter change
Spark plugs
Brake fluid change
Bit more involved
Coolant flush and change with fresh anti freeze
Power steering fluid change
Clutch fluid change
Diff oil and gearbox oil change
Then checking for perished pipes damage etc etc etc ....
SVA no idea, what category was the damage?
BROOMY
Post Wed Dec 10, 2014 11:09 pm
I'm not sure at the moment .
Was just a bent subframe and maybe rear wishbone trailing arm.
Well I think you would call it small.
BHadley
Post Wed Dec 10, 2014 11:17 pm
I'm sure dvla has more info on the SVA .
Must have been a hard blow to bend a subframe !
BROOMY
Post Wed Dec 10, 2014 11:22 pm
Turned right into a solid post in a dark car park .
Silly mistake of my mum
BROOMY
Post Sat Dec 13, 2014 4:15 pm
Brake fluid renewed and oil filter + oil.
So now I have the plugs and fuel filter to renew.
Then I'll do the power steering fluid.
What power steering fluid is advised to use?
BHadley
Post Sat Dec 13, 2014 5:05 pm
Dextron 2. There is a good guide on the wiki of how to change it.
Busy day then ?
BROOMY
Post Sat Dec 13, 2014 6:10 pm
Not busy with the car .
My mum doing my head in about her extractor .
6 bolts but I had to screw in as well as hold it .
Is dextron 2 atf fluid?
BHadley
Post Sat Dec 13, 2014 6:48 pm
Yes dextron 2 is ATF fluid also known as power steering fluid. You could also use dextron 3.
The instructions on The wiki are very good prob need about 2 litres to flush and refill.
Smart extracter fan that! Family, always jobs that need to be done!!!
