Strut Mounts And Chassis Info .......
sindako
Post Fri Nov 28, 2014 7:21 pm
Hello Zoners .
I was Wondering ,
Are All E30's Have The Same Dimensions For Chassis And Struts .
Dunno , IF Any Of You Have An Original Strut Brace it Will Be Great to See the measurements ....
Today , I Went down stairs and Removed my Old Strut Brace and i Installed a New TA Technix One , Aluminum . It Couldn't Take More than 111 cm in distance .
When I did Measure the Distance between the Outer Strut Bolts
The Distance Is 110cm ,
On the Diagram for Chassis Dimensions , the distance is
caroliner Fenwick : 111 cm
celette : 111.2 cm
Nicator Systems : 110 cm
Blackhawk : 111.2 cm
So I Still Don't Bloody Know Where am I now .
I Measured The Distance and it's 110 as i said before .
Is It Ok Or are the Struts Leaned To The Inner Side .
My Car is Originally A 318i
Now it Sets on a 327i
Is It Leaned Inner ways ?
PS : No Cracks In Body Work or Arches or Struts , The Car is Still Sharp and nice , Did 200 km/h In it , and it's Stable .
Resources :
(Chassis Dimensions and Mounting Measurements)
https://www.mediafire.com/?e5vsdoo2ej6sh7z
Cheers.
Kos
Post Fri Nov 28, 2014 7:26 pm
It's very common to see the struts move inwards over the years
I don't have the dimensions to hand to check exactly what it should be
Post Fri Nov 28, 2014 7:29 pm
All E30's share the same strut tower dimensions and mounting points with the exception of the 325iX.
As a note, cabrios have reinforcement plates between the strut tower and the inner wing.
