Plans for this weekend, remove the gearbox from the 316 I'm breaking.
Prop is already off and the car is on blocks about a foot or so off the ground.
Anything I need to bear in mind, or hints and tips for an easier life?
thanks in advance.
Gearbox removal
Grrrmachine
- E30 Zone Wiki / Team Member
This guide outlines pretty well how to go about the job:
http://www.e30zone.net/e30zonewiki/inde ... ing_Clutch
jimbom30cab
- Tech 1 freak
If you have a crane or block and tackle, i would lower the whole front subframe with engine still attached onto the deck, taking the front struts off would help also.
