Rear floor
hazza
Post Thu Nov 20, 2014 7:04 pm
Hi all
Poking around my E30 325i today I found the rear left passenger floor around the small circle panel is pretty poor in condition , can you get floor repair sections or panels ? Anyone else done there's or is it simply cut out and weld a patch in ? Corrosion is from the circle panel outwards around about 3 inches max .
Cheers Harry
jjch325i
Post Thu Nov 20, 2014 8:00 pm
The panels are available separately from the dealers ( not to expensive) and are seam sealed in .
jjch325i
Post Thu Nov 20, 2014 8:04 pm
Part no 41128200462
Grrrmachine
E30 Zone Wiki / Team Member
Post Thu Nov 20, 2014 8:11 pm
The round panel itself is replaceable, but if the edge of the hole is corroded then you'll need to fabricate your own patch out of 0.8mm steel.
Gert_8
Post Thu Nov 20, 2014 8:49 pm
/\ didn't you do that on your touring resto thread, Grrr. Post the link.
Grrrmachine
Post Thu Nov 20, 2014 8:54 pm
Nah, my rear floor was probably the only part of the shell that didn't get any welding. Still, the resto link is in my signature if the OP is interested.
si911t
Post Thu Nov 20, 2014 9:47 pm
How much does it devalue a car if it gets say new rear arches quarter panels battery area etc ?
BenHar
Post Thu Nov 20, 2014 10:41 pm
si911t wrote:How much does it devalue a car if it gets say new rear arches quarter panels battery area etc ?
Compared to leaving them rusty and gaping?
Only Pacerpete pays more for that.
Ben
Gert_8
Post Thu Nov 20, 2014 10:47 pm
How can it devalue the car?! :mad:
si911t
Post Thu Nov 20, 2014 11:20 pm
Ha no what I meant is if for example you have a sport 100k miles, 1 owner , never been welded/restored, no rust etc that's worth 10k and then you have sport same mileage owners etc but it's been restored with new rear arches and quarters but done to high standard like e30 topless beardtmatt would do with all work documented etc
how much lower would the price of the restored one be ?
Hope this makes bit more sense
hazza
Post Fri Nov 21, 2014 5:38 am
Ok thank you everyone for the help , I'm going to get some material and carry out a repair , I will post the results so let's hope my welding is still good enough !
Grrrmachine
Post Fri Nov 21, 2014 6:09 am
si911t wrote:Ha no what I meant is if for example you have a sport 100k miles, 1 owner , never been welded/restored, no rust etc that's worth 10k and then you have sport same mileage owners etc but it's been restored with new rear arches and quarters but done to high standard like e30 topless beardtmatt would do with all work documented etc
It's a completely arbitrary factor that's impossible to quote. Some people will pay more for a car with documented repairs, others will pay less. Of course, factory-fresh cars that have never been repaired will always be worth more, but it's incredibly unlikely that you'll find a car like that, with no rust, but 100k on the clock.
si911t
Post Fri Nov 21, 2014 8:53 am
Thank you
I love 'incredibly unlikely ' . Gives me some confidence to go and look at getting mine done properly.
Gert_8
Post Fri Nov 21, 2014 9:44 am
Always get any work done properly - bodges get found out and you won't have to pay twice for the same work in a shorter space of time.. :)
si911t
Post Fri Nov 21, 2014 11:32 am
Gert_8 wrote:Always get any work done properly - bodges get found out and you won't have to pay twice for the same work in a shorter space of time.. :)
normally i would go for bodge and cheap but this deserves a proper job. I just looking for someone around manchester who can take it on, but I want it documenting so when its does go , new owner knows that they are buying a decent one.
hazza
Post Thu Nov 27, 2014 6:45 pm
My repair is all done and looking perfect , very happy result ! 8)
si911t
Post Thu Nov 27, 2014 11:37 pm
hazza wrote:My repair is all done and looking perfect , very happy result ! 8)
Any pics
hazza
Post Fri Nov 28, 2014 6:33 am
When it's light out I will get some up
