Heated seat plug
BMG
Post Wed Oct 15, 2014 11:05 am
Is the heated seat plug available ? The plug under the seat connecting to the look that is. Can't seem to find it on the ETK.
BMG
Post Wed Oct 15, 2014 11:29 am
Yeah, as in this pic where the seat would be. I have to order a few BMW bits, so was hoping to find the correct plug rather than chop and fit something different.
bmw9818
Post Wed Oct 15, 2014 7:19 pm
ive got a couple lying around i think, I should have two which I cut off the old burnt out elements when i replaced them with new ones,
il have a look you can have them if you want
BMG
Post Wed Oct 15, 2014 9:06 pm
bmw9818 wrote:ive got a couple lying around i think, I should have two which I cut off the old burnt out elements when i replaced them with new ones,
Hi, thanks for the reply. Have asked Cotswold BMW if he can supply these along with a few other bits, but if as I suspect they aren't available, that would be most helpful, if you are sure you don't need them ?
