Cutting out
Millhouse
Wed Sep 10, 2014 7:07 am
My 316i has started to just cut out it will start up right away tho if you pull the clutch in it cuts out any ideas can't really say more than that do you think a good service ? Ie plugs leads dizzy and rotor arm would help it out
Nobby_N
Wed Sep 10, 2014 7:58 am
Take it round Homer's and get Barney to have a look for you, ive heard hes a dab hand with the spanners! :D
Millhouse
Wed Sep 10, 2014 8:22 am
Yea thanks for the reply really helpful a‘Ža‘Ža‘Ž!!!!!!
Nobby_N
Wed Sep 10, 2014 8:28 am
when you say "pull the clutch" do you mean when you realease the clutch or engage the clutch?
Millhouse
Wed Sep 10, 2014 8:56 am
Push the clutch in it cuts out but start straight away could it be an air leak ? It's not doing it all the time tho ?
Captain_Birdseye
Wed Sep 10, 2014 12:58 pm
You're stalling it.
Millhouse
Wed Sep 10, 2014 1:10 pm
Ha
bmw9818
Wed Sep 10, 2014 8:54 pm
Nobby_N wrote:Take it round Homer's and get Barney to have a look for you, ive heard hes a dab hand with the spanners! :D
id say Millhouse's ol man should be able to sort it, if not Duff man,
Millhouse
Thu Sep 11, 2014 5:58 am
Well that's proper help that is if you ain't got anything helpful to say best stay quite really as you ain't helping anyone
Nobby_N
Thu Sep 11, 2014 7:18 am
Quiet, Mrs Criboble did not do a great job with u
Millhouse
Thu Sep 11, 2014 7:53 am
What's the point in asking a question when you get stupid answers back puts people off
Nobby_N
Thu Sep 11, 2014 7:55 am
Were only playing man, Dont have a cow! :D
Millhouse
Thu Sep 11, 2014 8:17 am
Not really much help tho is it when your asking a question and keep getting stupid answers not what the forum is for
jmc330i
Thu Sep 11, 2014 9:52 am
Maybe posting in the E30 technical help section would be more useful - that's the point of it being there.
James
'91 325i Sport
'93 318i touring 16v
Millhouse
Thu Sep 11, 2014 2:46 pm
But my point is Morrons answering with stupid comments when all I wanted was advice
Captain_Birdseye
Thu Sep 11, 2014 3:07 pm
Might be a loose air hose/hole in the air intake somewhere. Have a quick look. So are you catching the school bus with Otto Man until you get it sorted? :rolling:
Thu Sep 11, 2014 4:34 pm
Does it cut out if you rev it a little, then push the clutch pedal down?
Sounds like it could be a worn release bearing, causing too much friction (dragging).
Millhouse
Thu Sep 11, 2014 4:42 pm
Iv sorted it now thanks
Captain_Birdseye
Thu Sep 11, 2014 5:37 pm
what was wrong dude?
Nobby_N
Thu Sep 11, 2014 7:14 pm
duff spark plug I bet!
Captain_Birdseye
Thu Sep 11, 2014 9:27 pm
Ha, what you mean the one he bought from duff man
Millhouse
Fri Sep 12, 2014 4:32 pm
It was the throttle cable that was so loose that was causing it to only idle at 500rpm so I took the slack up and put it to 900rpm idle and it never cut out again plus the dizzy cap and rotor arm was so poor so cleaned them up untill I get some new ones
Grrrmachine
E30 Zone Wiki / Team Member
Fri Sep 12, 2014 5:50 pm
Did you ensure that the Throttle Position Switch wasn't affected? What you've probably done is introduced a new fault to cover up an existing one, and your car now has no idea when it should be idling. This will lead to it running rich, sooting up your spark plugs, higher fuel consumption and all sorts of other pointless issues.
Make a new thread in the Tech Section, and you'll get proper help.
Fri Sep 12, 2014 8:32 pm
Throttle cable has no control on idle speed, other than if it is too tight and doesn't allow the throttle to fully close, then obviously it won't 'idle' at all, and will rev at whatever the cable pulls the butterfly to.
Grrmachine is correct in all that you've done is add another fault, and in that you got all the daft replies because you posted in the wrong forum. Arseing around is permitted in this forum, but any attempt to do so in 'tech help' will soon be dealt with by Grr, myself, or one of the other mods.
You will have an inlet side air leak or a TPS fault most likely.
Millhouse
Fri Sep 12, 2014 9:15 pm
Well it sorted it and it don't seem to be over fueling runs sweet as a nut so I'm happy
BenHar
Sat Sep 13, 2014 12:12 am
He doesn't want to be helped.
Ben
Millhouse
Sat Sep 13, 2014 3:41 pm
It's fixed when I asked for help people just took the piss
Mitchen
Sat Sep 13, 2014 3:44 pm
When your fix leads to bigger problems, I'm sure you'll be back.. just make sure you ask in the technical help section. The trolls won't get at you then.
1990 320i Coupe SE
viewtopic.php?t=253048
Grrrmachine
Sat Sep 13, 2014 4:28 pm
It isn't fixed, it's double broken. But by all means, enjoy your increased fuel costs.
Millhouse
Mon Sep 15, 2014 3:24 pm
Well the fuel hasn't changed abit so all is well at the min
