Temp gauge
Millhouse
It seems to have a mind of it's own for some reason is it just had it or can it be fixed ?
You don't give us many details to work on, but the chances are that tightening the small nut on the back of the cluster, directly behind the gauge, will cure the problem.
Millhouse
That's pretty much the only details I have it flicks about like a anything
Mitchen
He means car, year etc.
milescook
Still, echo Brian's comment - there's a mega guide for getting the cluster out without breaking anything or swearing here: http://www.e30zone.net/e30zonewiki/inde ... eplacement
Tighten that nut and give it a go.
Also please help the race budget by watching some videos
https://www.youtube.com/cookracinguk
Millhouse
Cool il give it a go but for now I'm off night fishing lol
Millhouse
One last thing it's runs quite lumpy at the min is there anything I can do to get it to run a little smoother ? As it's an injection is there stuff I. Can do to make it run nice
The usual things: Find and deal with air leaks on the inlet side, get the injectors rebuilt (see trader's section), check the operation of the throttle position switch, and check out the engine temperature (blue) sensor.
milescook
The above points can all be found in the wiki if you're unsure.
Millhouse
The little brass nut was lose and on the fuel gauge there ain't even a nut or washer !
Millhouse
Any one now were I can get the brass nut and washer from ?
Sitting here in the sunshine in Western France, I can't remember what size it is, but if it's 3.5mm, then that's a common size used in mains electrics, and any electrical wholesaler should be able to help you out.
Millhouse
All I no it's a 7mm socket fits it
Take out one of the screws that holds the electrical sockets and switches to the wall in your house, and see if it's the same diameter. Unless your wiring is pre 1970, these are 3.5mm
