Rear bearing
Millhouse
Post Mon Aug 25, 2014 10:03 pm
On a scale of 1-10 how hard would it be for my self to do rear wheel bearings ? As il on be on my drive with an average tool kit ?
Grrrmachine
E30 Zone Wiki / Team Member
Post Mon Aug 25, 2014 10:15 pm
9.5. Pay someone else.
Read this thread if you want to see how it goes when an amateur attempts it:
http://www.e30zone.net/modules.php?name ... c&t=250464
kieran325
Post Mon Aug 25, 2014 11:00 pm
I had the rear bearings done on the M3 a few weeks back, took all day and my mate charged me £200 and I got OEM bearings from BMW.
Nasty job by the looks of it.
TPS
Post Mon Aug 25, 2014 11:17 pm
I had my Nearside rear done by my Mechanic, it had seized in, they was lots of swearing, I'll echo whats been said above, get someone else to do it, a real PITA
Post Tue Aug 26, 2014 12:33 am
With the correct tools it can be done in an hour and a half a side.
Post Tue Aug 26, 2014 12:36 am
Sometimes less!
**BANNED**
Post Tue Aug 26, 2014 6:54 pm
I needed to swap a rear wheel bearing a few months ago.
I was able to remove the driveshaft and trailing arm with out too much swearing,then I gave in and took the arm to the local garage to have the old bearing pressed out and the new one pressed in.
Youth is wasted on the young.
capnmchl
Post Tue Aug 26, 2014 7:13 pm
Once again, for those who are home DIY'ers:
By all means take the arm off the car yourself. It's not all that hard. But please please please take the arm to a garage and get them to remove and replace the bearing. If you want to learn then I'm sure you can stand around and watch if you're not in the way.
Most garages will swap the bearings for a bit of beer money.
Millhouse
Post Tue Aug 26, 2014 7:50 pm
If I bought new rear arms then had the new bearings pushed in then I could just replace old for new ?????
