Blown Fuse Maybe
jon-m42
Post Thu Aug 14, 2014 8:35 pm
Evening Zoners,
Today I set of for work in the morning in the old girl. Everything was fine arrived to work an hour later and parked her up.
In the evening I was set to go else where to a friends house. I did not know how to get there so he gave me his post code and I plugged the tom tom in to the cigarette lighter connection.
Ten minutes into my journey the tom tom battery stop charging and the tom tom light dimmed. Which was strange.
I arrived just about with what little battery life was left in the ole tom tom.
I parked up and also noticed that after switching engine off and the key out the ignition I open my doors and test if the electric windows would go down and nothing where as before this would work fine.
I think it may be the cause of a blow fuse but im not sure?
If this is the case which fuse would i need to replace ?
The car is a absolutely standard 1990 318iS.
Jon
Maxtek
Post Thu Aug 14, 2014 8:51 pm
If it is a fuse then possibly 28? Worth checking to see if the Fuse looks blown.
http://www.e30zone.net/e30zonewiki/index.php/Fuse_Box
jon-m42
Post Thu Aug 14, 2014 9:02 pm
Maxtek wrote:If it is a fuse then possibly 28? Worth checking to see if the Fuse looks blown.
Thank you for the help bud I will check this first this tomorrow morning.
Thanks again ;)
Post Thu Aug 14, 2014 10:20 pm
Then you will need to work out why it blew!
jon-m42
Post Fri Aug 15, 2014 11:11 pm
Brianmoooore wrote:Then you will need to work out why it blew!
very good question another task i am not fit for. I changed the fuse and all seems fine now back to normal again.
Post Fri Aug 15, 2014 11:21 pm
Check for any metallic debris in the bottom of the lighter socket.
jon-m42
Post Mon Aug 18, 2014 5:45 pm
Brianmoooore wrote:Check for any metallic debris in the bottom of the lighter socket.
Did just this and I found allot of dirt and grit inside the lighter socket. This was rather surprising considering i do not and never have smoked.
I only every use the lighter docket to charge my phone and to use the tom tom on the rare occasion I am going to a place i have not been to before.
I cleaned it out and now it is all put back together.
thanks for the advice/helps guys.
Jon
winkeye
