Bit of a prob
BROOMY
- busy saving Clifford
Started to tighten my exhaust manifold.
Which ment removing the HT leads etc and I swear I put them back right .
Now it won't start?
Sounds like it has a killswitch somewhere but never before.
What could it be?
Now it won't start?
What could it be?
HairyScreech
Did you disturb the king lead?
I reckon it's your alarm ........
BROOMY
Am I ment to put a lead on first?
I unplugged the 2 things below the HT leads that plug into the coil pack I'm sure I put them back how they came off .
Would that cause it not to run?
BROOMY
Tomorrow I'll just unplug the alarm then all sorted.
Which engine do you have? I would imagine that the coil pack is polarised, so quite important to fit the LT leads the correct way round.
BROOMY
M42. I fitted the leads correctly as they were numbered.
All ran before just needed the manifold doing up.
BROOMY
If you don't fit the ht leads the right way round , what will happen ?
It will usually run, but roughly, as if it's out of balance.
BROOMY
But this has a coil pack not a distributor.
So should run fine shouldn't it.
Yes, but unless the firing order is correct, it won't run properly.
Try removing an HT lead, fit a spare spark plug into it and rest the plug on a metal (earthed) part of the engine, then crank it over and check if it sparks.
BROOMY
Yes they all spark that's where I'm stumped and all getting fuel.
But doesn't wanna run even Though it has original ht leads with the numbers printed on them.
In that case, perhaps you've flooded it? May be worth leaving it for a few hours, perhaps with the spark plugs removed.
Alternatively, crank the engine over while spraying carb or brake cleaner down the throttle body.
BROOMY
Ok tomorrow I'll try that.
Going cinema later and I'm not at home right now.
BROOMY wrote:M42. I fitted the leads correctly as they were numbered.
M42 you say ? Now it is all starting to make sense......
BROOMY
I feel stupid but the plugs were soaked.
On any of my bikes this never happened but maybe coz my bikes were carbed.
So you managed to get it started?
Good to hear that.
BROOMY
Tightened a stud and it came out.
So tomorrow get some lock tite n bang it back in there .
Studs aren't held in by Loctite, they're held in by threads - things which I think you'll find are missing in your head behind this particular stud.
BROOMY
Didn't just come out was loose undone by hand so that's why I plan on redoing it tomorrow .
You'll probably need more than plain Loctite - try thread lock.
http://www.loctite.co.uk/threadlocking-4476.htm
BROOMY
How deep are the threads in the head from the exhaust ?
Are the exhaust ment to have a spacer sort of thing?( a silver plate thing) not the gasket , it's thicker than that
BROOMY
What about if the threads are stripped what should I do?
Bit awarded to helicoil it as it's on a freshly fitted head I believe.
You could try using a tap & die set to re-cut the thread, or you may have to drill it out and re-tap it to the next size up.
BROOMY
I'll hope for the best tomorrow and report back.
BROOMY
It doesn't seem to run again .
Plugs are dry fuel pump doesn't click need help
Sounds like it could be a duff crank position sensor, or the fuse to the ECU/fuel pump has blown.
BROOMY
But wouldn't a diff crank sensor not allot it to spark aswell as the engine not knowing its position
You haven't said whether you have sparks or not.
