e30 obd tool
McGoo
where can i get an obd tool for my e30 to read any fault codes and such?
thanks
thanks
Grrrmachine
- E30 Zone Wiki / Team Member
Same place you get magic beans and unicorn food.
The ECU in most E30s is so primitive that you might as well try to read the smoke signals coming out of the exhaust if you're looking for "fault" codes.
Well engine dependant you can get some basic fault codes from the DME fitted to some E30's.
Sept '87 on M20's, M42's and M40's can be read.
BMW DIS reads them as did an old snap on scanner i had.
pony
- I have been misbehaving and am sorry !
What about on Tech1 Sports ? Presumably no ?
Not that i am aware of but i guess the early motronic 1.0 cars could be hooked up to the very old BMW service tester for some basic diagnostics.
pony wrote:What about on Tech1 Sports ? Presumably no ?
I don't need a scanner to tell you they are all patched up hanging turdz !
pony
So aren't the fault codes meant to be read as part of BMW Inspection II Service ?
Mine is Motronic 1.1 I think ?
pony
Doesn't the latest BMW service tester connect to them ?
I find it odd only works with the old ones as I thought the new diagnostics would cater for all old BMWs from when OBD was first introduced to BMW vehicles
pony
Those donuts , burnouts are pretty happening for a "patched up turd"pacerpete wrote:pony wrote:What about on Tech1 Sports ? Presumably no ?
Yes where possible/applicable.pony wrote:So aren't the fault codes meant to be read as part of BMW Inspection II Service ?
Nope!pony wrote:Doesn't the latest BMW service tester connect to them ?
The latest ISID doesnt even connect to any E30 where as its predecessor BMW DIS would.
pony
I want to get the M3 CS read
At ML it was spitting out fault codes
They cleared it but said to keep an eye out should the fault codes come up
A lot of codes are stored in modern cars when there isnt anything actually wrong. Some times just codes stored for occurrences in the cars systems such as alarm triggers or brake fluid level low for example.
pony
Yes was seating heating and Double VANOS. This had New Genuine BMW Double VANOS @31k mileage / 2012.
e30rapidic
have you tried the stomp test? Turn the ignition to the "on" position and press the gas pedal 5 times. The red check engine light in the cluster will flash in succession
bab-91
A screwdriver makes it more enjoyable.
IG - bab91
IG - bab91
Grrrmachine
This doesn't apply to UK vehicles.e30rapidic wrote:have you tried the stomp test? Turn the ignition to the "on" position and press the gas pedal 5 times. The red check engine light in the cluster will flash in succession
