Suspension pads
mods
Post Mon Jun 23, 2014 11:29 pm
Hi im going to fit pro sport coilovers to my cab, i was thinking of fitting new rubber pads, im a bit confused as thier are few different sizes in thickness in them, why is that? Also would it be wise to change the front and rear top mounts as well, thanks
Post Mon Jun 23, 2014 11:51 pm
It's similar to the '80s Mercedes, so you could adjust the ride height without having to change the springs.
Quite handy if a previous owner has fitted lowering springs and your sump keeps getting knocked, like on a Merc 190E I once owned.
mods
Post Tue Jun 24, 2014 12:03 am
Should i go for the thicker ones and i could adjust them with the coilovers as i want a decent stance not to low and would like it to be comfortable as well when driving. What are costs for front and back. Cheers
Post Tue Jun 24, 2014 12:28 am
Go for a size that give you an appropriate ride height with the springs you are using.
For prices, try asking Cotswolds on here...
mods
Post Tue Jun 24, 2014 12:53 am
Thanks will check them out.
