Brake pipe
Mitchen
Post Fri Jun 20, 2014 9:37 pm
Stupid question but what's the difference between the 'rear outer' and 'inner rear' brake pipes?
I just want the one that comes out of the rear drums, as they're rusted to pieces.
Any comment appreciated
1990 320i Coupe SE
viewtopic.php?t=253048
Grrrmachine
E30 Zone Wiki / Team Member
Post Fri Jun 20, 2014 9:56 pm
The rear brake system has four rubber hoses; a pair from just under the fuel tank to the trailing arm (inners) and a pair from the trailing arm to the drum or caliper (outers).
Mitchen
Post Fri Jun 20, 2014 9:57 pm
Grrrmachine wrote:The rear brake system has four rubber hoses; a pair from just under the fuel tank to the trailing arm (inners) and a pair from the trailing arm to the drum or caliper (outers).
Perfect! Thanks
1990 320i Coupe SE
Post Fri Jun 20, 2014 10:05 pm
Only two flexis on the rear of a drum braked car Mr Grrr
Disc braked rear has 4 rear flexis
Mitchen
Post Fri Jun 20, 2014 10:26 pm
I'm sure my pipes are copper as well. Does this make any difference?
1990 320i Coupe SE
**BANNED**
Post Sat Jun 21, 2014 2:34 am
Mitchen wrote:I'm sure my pipes are copper as well. Does this make any difference?
Kunifer is the best choice,unless you are an OEM bufftie,when only dealer supplied steel will do.
Flexible pipes are fitted between moving parts,rigid pipes where there are no moving parts.
So a flexible join is needed from the car frame to the trailing arms,and to the rear disc,but not to a rear drum.
The caliper slides,the drum stays in the same place.
Grrrmachine
Post Sat Jun 21, 2014 9:18 am
DanThe wrote:Only two flexis on the rear of a drum braked car Mr Grrr
Bugger :o: No experience with the poverty brake system.
Mitchen
Post Sat Jun 21, 2014 1:12 pm
Apparently the dealer no longer supplies, so any steel will have to do! What's the quality like on this kunifer? anyone had any issues or all good?
1990 320i Coupe SE
Post Sat Jun 21, 2014 1:27 pm
No downside on kunifer at all, other than the not OEM one. Bends easily, flares easily, doesn't seriously corrode, doesn't readily kink, cheap to buy. All you can want from a brake pipe!
Jozi
Post Sun Jun 22, 2014 8:43 am
I recently did all my brake and fuel lines using kunifer, didnt like the job but the stuff is easily bendable and workable. I got it of ebay a kong time ago.
Mitchen
Post Sun Jun 22, 2014 1:07 pm
Cheers guys. lets see how I get on!
1990 320i Coupe SE
