dare rs's and gaz coilovers help needed
aarc
craigieeb
30mm spacers are a bit extreme,
the poor thing will look like its on rollerskates
The only way to tell really is to offer the wheel up and measure
M50 Turbo!!!
I shall say no more
harry_p
Without knowing the offset no one is going to be able to offer much help.
cheers,
harry
harry
MattT
30mm will be abit crazy, even on standard wheels. I`d wager on those wheels it`d look abit stupid and need lots of arch work.
What ET are the dare`s?
Jozi
Hate to say it but you might have been better of with a staggered setup, narrower front so you can space them out a little and have not problems.
Look into getting a shorter spring also, BC do shorter stiffer ones and they also had a barrel type (I think), maybe you can get similar for your coilovers?
brian_s
www.dfaulknersprings.com they're the boys to speak to, they'll make you springs in whatever length, size, poundage you need
