reverse lights
corky
is the e30 318i manual reverse light switch prone to breaking down
Gouki
if your talking about the reverse light switch thats under the gear gaiter then a possible yes as mine is gone!
smithy318i
the switch is screwed into the gearbox. isn't it?
not prone to failure afaia
Gouki
no they are im living proof of it as mine have died cut the wires and tested them by shorting them together, reverse light comes on, connect to the switch nothing happens! had the same problem with my front and rear fog lights, turned out to be the foglight switch!!!
corky
is it easy to get to as need to sort for my mot
eko
- Old timer
Corky PM me your address over mate so i can post these covers.
Deleted the last time by mistake
Zayyan
You don't actually need reverse lights for the MOT.corky wrote:is it easy to get to as need to sort for my mot
But yeah it's a piece of piss to get to, just take off the gear gaitor and it's under there.
Richard I sent yours today by the way, did you send the cheque?
Gouki
yeah shouldnt be a problem, just remove your gear gaiter and the switch plug is right there i've just bought a replacement off Zayyan so I'll let you if my masterplan works!corky wrote:is it easy to get to as need to sort for my mot
Zayyan yes I've bunged a cheque in the post for ya!
