I jist spent some time earlier with a wire brish cleaning my discs and was wondering what would be the handiest to stop them corroding again?
I would like to zinc plate them but i cant do it myself and I cant afford to get it done, not sure who does it either. Would it be possible to paint them up with hightemp paint or would thos mess with the performance of the brakes?
Painting brake discs?
Jozi
Jozi
As much as id love to drive it i just cant because im mid rebuild so tuats not an option. I cleaned them up before a year or maybe two ago and they have rusted plenty since
- E30 Zone Meets/Events Team
WD40 them and put them away.
When you need them , use brake cleaner to clean them.
bab-91
Keep them in your vacuum jar.... doesn't everyone have one?
You going to this Shindig in Kildare on Sunday?
IG - bab91
IG - bab91
Not a good idea: WD40 displaces water for 40 days then it attracts water!Rav335uk wrote:WD40 them and put them away.
I've had no issues Maurice doing that.
rich318i
I hear Fred flit stone is selling some stone discs never rust.
bigbird76
You will be able to paint the centres ok with high temp paint or spray or probably hammerite.
As for the disc faces i have seen stuff that you can paint on to stop corrosion.
I am not sure what it is called but if you go to a machine shop who has lathes and milling machines and ask them they will probably tell you. It paints on like paint but dries clear and is a waterproof coating. They use it to protect parts whilst they are kept on the shelf. Obviously clean it all off with thinners or something when you take the car out in the summer etc.
Leigh
Leigh
Jozi
My vacuum jar isnt big enough to hold them! Ill be there sunday alright.
I might paint some and wd40 the rest or see can i find a machine shop and find oit what they use.
Them stone discs wont be much good to me since the holes on the floor were patched up!
