Rocker cover stud snapped
initial_g
- E30 Zone Moderator
Ive snapped one of the studs for securing the rocker/cam cover down on my m20, does anyone have a contact for getting a replacement? Its not leaking but im worried it will when I put her through her paces on track. Ive tried main dealer with no avail. Thanks in advance graham.
How much of the stud is remaining? If there's a fair bit, you could either MIG-weld a nut on or tighten two nuts against each other to unscrew it.
Try Cotswoldbmw on here for a replacement:
http://www.e30zone.net/modules.php?name ... forum&f=39
Explain further. This is a stud used on M20, M21, M30, M42, M70, M73 and a few other engines and should be readily obtainable.initial_g wrote:Ive tried main dealer with no avail.
BMW UK take a dim view of unhelpful dealers.
It's a M6 x 40 stud, and can be replaced by a bit of M6 studding or a sawn off bolt.
The fun part will be getting the old one out.
initial_g
Cheers speedtouch ill give it ago winding it out, there is still quite abit sticking out.
Brianmoooore cheers for that im going to raid the fixings at work and make one I recon. I phoned derby stratstone and he said its not somthing theyed beable to get hold of, and to try a breakers :/
hennared323i
Report the idiot to BMW UKinitial_g wrote:Cheers speedtouch ill give it ago winding it out, there is still quite abit sticking out.
initial_g
Tbh it was feb I called.. I should have taken his name really... its one of those jobs ive been meaning to do since last summer but because its been in storage over winter its been on the back burner
