New bolts need for rear subframe
Jatin
Post Sat May 24, 2014 12:53 pm
I been refurbishing the rear subframe aand related bits.
Some of the bolts needed heating to loosen them. I guess I need new bolts all round as the heating ruined then. Where do I get new ones apart from the stealer.
Post Sat May 24, 2014 1:56 pm
Trailing arm bolts? They are a fine pitched M12 with a long shoulder, and im sure they are a high tensile bolt too, so they are not an off the shelf bolt at all, if you wanted to replace them like for like you would either have to buy from a dealer or have some made.
I would not recommend using a standard bolt
Jatin
Post Sat May 24, 2014 2:19 pm
Thanks what about the bolts holding the driveshaft to the diff
zd3bx
Post Sat May 24, 2014 2:21 pm
Jatin wrote:Thanks what about the bolts holding the driveshaft to the diff
They normally come included in the kit, when you buy an inner boot for the driveshaft.
Post Sat May 24, 2014 9:28 pm
These are 10.9 grade. Most cap bolts are 10.9 in my experience, so you should be able to get them from a fastener specialist.
Post Sat May 24, 2014 9:38 pm
What's wrong with just buying the correct bolts from a BMW dealer?
bigbird76
Post Sat May 24, 2014 10:02 pm
I bought the capheads from stealers and i do not have the receipt to hand but they are not too expensive tbh. Or like Brian says a fastener specialist,
Also do not use stainless steel on any suspension parts if your thinking of doing it.
Leigh
Craggy73
Post Sat May 24, 2014 10:18 pm
The trailing arm bolts (33321136406) cost me £7.39 each from BMW. Can't remember if that's before or after VAT.
Jatin
Post Sat May 24, 2014 11:06 pm
bss325i wrote:What's wrong with just buying the correct bolts from a BMW dealer?
Buying from the stealers is an ok option. It's just that I always assumed that they take the mickey with parts that should cost 50p. :?
the parts you require aren't 50p items. You'll be lucky to get plastic fasteners for e30s now at 50p each let alone suspension bolts
Jatin
Post Sat May 24, 2014 11:09 pm
Fair enough
Post Sat May 24, 2014 11:17 pm
Indeed, as I said previously a lot of the suspension bolts are specially made for the purpose, not an off the shelf item hence the higher price
PG325
Post Sun May 25, 2014 8:40 am
I bought the 12 shaft to diff bolts last week from Cotswold BMW, they're M10 x 50 and cost 73p each.
Jatin
Post Sun May 25, 2014 11:42 pm
That's not bad stealer it is then
