Rust Treatment?
Mitchen
Post Wed Apr 16, 2014 7:35 pm
I've taken the boot seal off because it was split. However before putting a new one on, I noticed the bottom lip where the seal fits has some surface rust.
I want to treat this before I fit the new one. What's the best option? Don't want to go into priming and painting etc. Just something that I can apply that will stop it in its tracks. Garage next to my work said there's a product which you just brush on that turns it back into solid metal, he didn't remember a name though :?
1990 320i Coupe SE
viewtopic.php?t=253048
hennared323i
Post Wed Apr 16, 2014 9:16 pm
Ha
Snake oil
Sand, anti rust stuff of your choice (search function) and prime as a bare minimum
Post Wed Apr 16, 2014 9:38 pm
There are three treatments for rusty steel:
1) Remove all traces of the rust with a wire brush, and paint.
2) Use a chemical (usually phosphoric acid) to convert rust into black iron oxide, which can be washed/wire brushed off, and paint.
3) Use a rust encapsulator which forms a hard coating over the rust.
BenHar
Post Wed Apr 16, 2014 10:03 pm
4) Cut it out and replace with new metal.
Ben
Mitchen
Post Wed Apr 16, 2014 10:23 pm
Thanks guys
I'm guessing this here will be a good bet
http://www.ebay.co.uk/itm/111136938038? ... 1423.l2649
I'll give it a crack! :D
1990 320i Coupe SE
Post Wed Apr 16, 2014 10:28 pm
Theres definately a joke there.........
Mitchen
Post Wed Apr 16, 2014 10:46 pm
pacerpete wrote:Theres definately a joke there.........
.. Intentionally of course! winkeye
1990 320i Coupe SE
