Anyone know where to buy the stuff like bmw fitted to our cars? I can only seam to find Dynomat or foam.
I thought x works bought some from the dealers but I cant find the number on realoem so wondering if anywhere else will do it.[/list]
where to buy sound deadening
appletree
kam-325i
polsta
eBay about 20 quid delivered for a load of sheets,,use search function, I can find the thread tonight I've got it saved on computer
Jozi
I'm using silent coat on mine, went for the 2mm stuff which seams very light but i'll be covering it over wit hanother sound deadening product before the carpet goes in.
Gavla
Can you explain the logic?Jozi wrote:I'm using silent coat on mine, went for the 2mm stuff which seams very light but i'll be covering it over wit hanother sound deadening product before the carpet goes in.
Jozi
The silent coat only covers partial area's (25-50% of a panel) and is to stop panels from resonating. Then the other product goes on over a layer of foam and these are to stop the sound passing through. To do it properly you really need a heavier version of silent coat, thicker foam and thicker sound proofing, but it all adds a lot of weight!
Jozi
There's a lot more to it than that, lots of info on here: http://www.talkaudio.co.uk/index.php/index.html
And this is also a good place: http://sounddeadenershowdown.com/how-to/
