Can anyone shed any light on this
My old exhaust manifold had a crack in it i discovered after it was all apart, so i got that other one off Jimbo and had it blasted and painted it
It was noticed the 6 (to head connecting) holes on the new one were a bit bigger than the holes on the old one, HKF thought maybe the old one was a 2.0 manifold not a 2.5
So when it came to fitting today - it was then noticed that it didn't fit the down pipe, BUT the down pipe manifold gasket i got from BMW this week (via car reg/chassis number) was the same/correct fit for the old manifold , slightly smaller
Its a 3 piece system pre facelift
So - what is the difference between the 2 sizes ? Is it a 2.0 - 2.5 thing, or a pre face/facelift thing ?
Not sure what to do ?
Do i need to get another manifold ? (Anyone got one?)
Or do i get a different front down pipe and use this manifold ? And if so would it give a better performance bring bigger holes ?
Appriciate any help as I need to get this sorted ASAP to get the car running
Exhaust manifold part 2
polsta
jimbom30cab
- Tech 1 freak
can you read off the part numbers from them both?
polsta
Not now I'm at work
What car did this manifold come off jim ? Any idea if your old engine was 3 or 4 stud downpipe ?
Been reading about , the wiki says pre and facelift are different
The pre 87 cars have a 3 stud down pipe connection, and after 87 had 4 stud
Wiki here are also "big and small" types of down pipe 4 stud connections
My downpipe is a 4 stud "small"
But this manifold (I got from you) is a 4 stud "big"
So I'm a little confused , is this a pre or facelift manifold or as And as to what I do ? Do I look for a different manifold or a different downpipe ?
polsta
Adit took the manifold home to line it up to the down pipes he has
He has one that fits it , but its a 2 piece system one I think, he said maybe could cut the pipes on it to size ?
Would a manifold with slightly bigger holes be better ?
Its all a bit confusing
Wiki -
On M20 engines the exhaust manifold has six branches, ending in a twin-port outlet, with the same design being used on both 320i and 325i models. However, there is a difference between pre- and facelift vehicles; manifolds before 1987 had only 3 studs for the downpipe, while later ones have the four studs for the downpipe. TO make things even more confusing, there are two sizes of 4-stud manifolds; small and large. When building an exhaust system, it is not possible to "mix and match" between these parts.
Wiki -
jimbom30cab
- Tech 1 freak
The manifold came off the 2.7 engine i got from Ajay last year.
gaszman
- E30 Zone Meets/Events Team
mines the 3 bolt larger one have a gasket smaller one supplied by ecp bmw came good though
