Gert_8
- Location: In your back passage faster than a rat up a drainpipe!
Post
Wed Mar 12, 2014 7:48 pm
Hi All,
Can anyone give me instructions on how to insert the heating mat into the seats, please.
Alternatively, post a link to the wiki (can't see anything there) or another site that might be able to help?
TIA!
jimbom30cab
- Tech 1 freak
Post
Wed Mar 12, 2014 7:56 pm
I popped my seat in to a local trimmers mate, they did a great job and it cost me £25 iirc. I did look into it but was told it's quite a fiddly job and I'm cr*p at fiddly stuff.
Gert_8
Post
Wed Mar 12, 2014 8:00 pm
Thanks Jim. I'm in Wales....... Don't think I'll find a trimmer around here. Plenty of sheep fiddling though
jimbom30cab
- Tech 1 freak
Post
Wed Mar 12, 2014 8:05 pm
oh, sorry, lovely part of the world though. if I remember B7 is a bit of a guru with bmw seats, might be worth a PM
Gert_8
Post
Wed Mar 12, 2014 8:08 pm
Oh, great. I didn't know that. I'll send him a pm for help. Thank you.
jonny323i
Post
Wed Mar 12, 2014 8:12 pm
The seats come apart really easy just time consuming.
I don't know where the elements are fitted though whether it's under the fabric above the foam or behind it
Touring for life
Gert_8
Post
Wed Mar 12, 2014 8:30 pm
Is there a guide on taking the seats apart, Jonny?
Gert_8
Post
Wed Mar 12, 2014 8:49 pm
Thanks Daimler
Gert_8
Post
Wed Mar 12, 2014 10:15 pm
diable wrote:Just use deep heat as Pacer suggested to Pony to keep your arse toasty
As pony discovered, you can't turn deep heat off like you can with heated seats, which explains why Pony's butt resembles a baboon's in season. (Pacers got the pics)
You can tell us, where does the heating element go; under or over the cushion and between the leatherz ?
Gert_8
Post
Thu Mar 13, 2014 9:47 am
diable wrote:in between the leather/vinyl and foam.
Thanks Buddy!
Jatin
Post
Sun Mar 16, 2014 9:25 pm
I tried fitting Retrofit heated seat elements some time back. Gaining access was quite easy once you take apart the back pole that the leather wraps around underneath. My problem was that getting between the leather and the foam would have resulted in ruining the attachments between the upper leather and the foam underneath. There is a lovely space between the upper and lower foam layers that the element just slides into.
I know that this will slow the heat getting your backside but I my opinion it's not worth ruining the end finish of the leather to get the elements right under the leather.
Does anyone have any opinions
Gert_8
Post
Sun Mar 16, 2014 9:40 pm
Did you take any pics? The heat is never instant so as long as they warm up, then the placement you mentioned seems very sensible. Thanks
Jatin
Post
Mon Mar 17, 2014 8:25 am
I'll get some for you
Gert_8
Post
Mon Mar 17, 2014 9:21 am
Thanks Jatin.
Jatin
Post
Mon Mar 17, 2014 9:37 pm
How do you post images
Jatin
Post
Mon Mar 17, 2014 9:46 pm
Found out how to do it. What a pain in the back side
Jatin
Post
Mon Mar 17, 2014 10:12 pm
Jatin
Post
Mon Mar 17, 2014 10:28 pm
How the f*ck do I put an image here
BenHar
Gert_8
Post
Tue Mar 18, 2014 8:16 am
Do you have a pic of the "slot" where you inserted the heating mat? Well done with posting a pic, it's a pain using photobucket or similar software to load them.
Jatin
Post
Tue Mar 18, 2014 8:19 am
Gimme a day or two I'll have to take the seat apart just for you
Jatin
Post
Tue Mar 18, 2014 8:23 am
Ps Benhar posted the photo for me. I'm still no closer. Show me please
Gert_8
Post
Tue Mar 18, 2014 8:47 am
If I remember correctly, with photobucket, once you have uploaded the image if you click on it you get a cog icon which then allows you to select - view all links(?)
The link you want to copy and past is the Img one. As soon as you click on ot, photobucket will tell it is copied. You the right click and paste into your post.
It will display this as a normal link, ie the standard written pathway, but if you preview your post you will see the image.
Try that.
Jatin
Jatin
Post
Tue Mar 18, 2014 4:09 pm
this what i typed above - no image
Jatin
Jatin
Jatin
Post
Tue Mar 18, 2014 4:14 pm
photo of slot coming up this evening
Gert_8
Post
Tue Mar 18, 2014 4:18 pm
Jatin wrote:photo of slot coming up this evening
Ohh err!!
Minimayhem81
Jatin
Post
Tue Mar 18, 2014 4:57 pm
Gert_8 wrote:Jatin wrote:photo of slot coming up this evening
Ohh err!!
ha ha
