Useful tutorial or guide to fit lowering springs and shocks?
stefano30
Post Fri Feb 21, 2014 6:49 pm
Received my spings and shocks set in the post today. Any good websites or guides for fitting them than somebody has used? Cheers
Grrrmachine
E30 Zone Wiki / Team Member
Post Fri Feb 21, 2014 6:50 pm
Yeah :D
Captain_Birdseye
Post Fri Feb 21, 2014 6:54 pm
I thought that handy diagram was Grrr's sig.
Grrrmachine
Post Fri Feb 21, 2014 6:56 pm
Maybe it should be :D
stefano30
Post Fri Feb 21, 2014 7:05 pm
Grrrmachine wrote:Yeah :D
Not seeing any sort of step by step tutorial in there.
Grrrmachine
Post Fri Feb 21, 2014 7:34 pm
jamlid
Post Fri Feb 21, 2014 8:01 pm
suedenim
Post Fri Feb 21, 2014 9:09 pm
PROCEED WITH CAUTION!!
Taken from this link:
http://www.e30zone.net/e30zonewiki/inde ... ing_Struts
10. Compress the spring.
Make sure that you compress the spring with a suitable spring compressor. Failure to do so may more than likely result in injury, the springs have a lot of stored energy.
If you're really not sure what you're doing, find someone who does!!
1982 E21 316 Baltic Blau
1989 318i 2 Door Sterling Silber
Feedback: http://www.e30zone.net/modules.php?name ... highlight=
bmw9818
Post Fri Feb 21, 2014 10:48 pm
^ +1 shitty halfords/ ebay specials will fail and it will take your head off, when compressing my original springs it broke loose as i tightened it and the spring embedded itself in my wall.
you live you learn though!
stefano30
Post Sat Feb 22, 2014 2:22 am
bmw9818 wrote:^ +1 shitty halfords/ ebay specials will fail and it will take your head off, when compressing my original springs it broke loose as i tightened it and the spring embedded itself in my wall.
Is it just the 2 front spings that need compressed?
suedenim
Post Sat Feb 22, 2014 2:28 am
Yes. Rears aren't under any real compression and can be levered out if you push the trailing arm down.
BenHar
Post Sat Feb 22, 2014 1:25 pm
suedenim wrote:PROCEED WITH CAUTION!!
I did mine with ratchet straps. They worked fine for holding the springs while I changed the shocks, but I'm not sure how it would go trying to compress a new spring with them.
Probably be OK.
Ben
jamlid
Post Sat Feb 22, 2014 9:07 pm
For some reason, no matter how much I push the trailing arm down, the rear springs are still incredibly tight..
Grrrmachine
Post Sat Feb 22, 2014 9:53 pm
You have to unbolt the anti-roll bar to get the trailing arms to drop down enough.
Post Sat Feb 22, 2014 10:03 pm
Don't need spring compressers. :D
BenHar
Post Sat Feb 22, 2014 11:24 pm
Rav335uk wrote:Don't need spring compressers. :D
For the rear springs, no.
Ben
G-Bear
Post Sat Feb 22, 2014 11:52 pm
Ghetto... Keep them on and keep it low...
Cypriotgeeza
Post Sun Feb 23, 2014 11:50 am
I've seen a spring shoot through the roof of my mates garage! Proceed with caution! :mad: 8O
Check my M30 build threads:
New Daily : viewtopic.php?f=34&t=285452
