6 branch manifold
whiterhino
A friend of mine has been offered a manifold for quite cheap.i haven't a clue what make it is and only have one picture of the manifold.could anyone with a beady eye maybe tell what manifold it is by the pic as I can't be arsed to drive to the guy as I don't even have an e30 at the minute.i know it's a long shot but if it turns out to be a goodun then ill buy it.as usuall my skills are useless on this iPad can someone pm me and I'll forward the photo thankyou.
M3 cecotto ultimate driving machine
steve_k
Get the pic up & I'm sure someone will tell you,
whiterhino
I don't no how to post pics Steve.if you pm me a number to send it to and don't mind putting it up please.
steve_k
No phone at the moment, try image shack or photo bucket, I'm the same as you I'm afraid
steve_k
I could be wrong but that looks life,e a magnex copy (ain't going outside to have a look at a genuine one as it's to cold/wet/windy,
If it's a real one it could be worth a few quid to the right folk.
E30_Aza
steve_k
That's true, as the exhaust pipe on number 6 goes under number five in the other pic
Well it can't be a magnex then so where's it from?? Never seem one like that before
& aza, your's look's just like mine except mine if wrapped in heat wrap
whiterhino
Does anyone have a clue?.or is it junk?
steve_k
Not junk, just to be honest it looks like sections from two totally different makes/models of manifold,whiterhino wrote:Does anyone have a clue?.or is it junk?
I'm sure someone on here with more knowledge than me would be able to shed more light on it.
whiterhino
It could be a btb crossed with hottuning
steve_k
You never know lolwhiterhino wrote:It could be a btb crossed with hottuning
Its a BTB2 copy.
steve_k
Hot tuning??bss325i wrote:Its a BTB2 copy.
Or the even shitter ebay hottuning copy!steve_k wrote:Hot tuning??bss325i wrote:Its a BTB2 copy.
steve_k
I forgot about them lolbss325i wrote:Or the even shitter ebay hottuning copy!steve_k wrote:Hot tuning??bss325i wrote:Its a BTB2 copy.
macas
Thrre is some pics in the wiki of 6 branches...maybe worth a look?
whiterhino
I checked the wiki and it looks like the btb one.not sure obviously but if its a copy does that mean its rubbish.how will I know if its genuine?
I can tell from that pic it's not a genuine btb. Just a cheap rubbish coppy.
whiterhino
Cheers bss. I thought it was too good to be true.
timmzey
Edited for privacy
Looks LHD to me.
timmzey
Edited for privacy
reggid
i know some pretty high powered m20 engines with a hot tuning manifold. it may not look as pretty but it still seems to perform well
E30 325is with M20B31
steve_k
Any links??reggid wrote:i know some pretty high powered m20 engines with a hot tuning manifold. it may not look as pretty but it still seems to perform well
ross_jsy
To be fair it has to perform better than the standard cast jobbie, purely based on the fact the primaries all seem pretty equal length and the diameter looks about right for the displacement.
suchy
- True Zone Relic
Maybe a dumb question but it's one I don't know the answer to (and yes could probably easily find out the answer on Google...)ross_jsy wrote:To be fair it has to perform better than the standard cast jobbie, purely based on the fact the primaries all seem pretty equal length and the diameter looks about right for the displacement.
What difference does having unequal primaries make to performance? Maybe the noise will be different but what about the performance/scaveging effect? Is it just so the engine pulses are kept seperate as they are forced into the rest of the exhaust system (if that makes sense?!!?)
ross_jsy
It's a little bit above me, but from what I understand equal length primaries (of the correct length and diameter, there are calculations to work this out) create a scavenging effect as the gases moving through the tube from one opening of the exhaust valve are still in the primary, sucking the subsequent pulse out when the exhaust valves open again.
Does that make sense?
There is a dyno graph on the zone somewhere of a before and after hottuning and it did increase mid range torque a bit but only gained like 1 or 2 bhp.reggid wrote:i know some pretty high powered m20 engines with a hot tuning manifold. it may not look as pretty but it still seems to perform well
All of the ht's I've seen in front me have been shocking! There is a pic I posted not that long ago of a primary of one, I will dig it out tomorrow.
E30_Aza
They are shocking! Barry will be referring to the one I had. It went straight back. They did understand what my problem was with it either. This to me proved that they had no interest in making a "performance" manifold. They said "but it is nice and shinny!"
timmzey
Edited for privacy
That was the pic i was going to post!
Mega fail!
Mega fail!
reggid
this engine uses chinese BTB copies im led to believe also the ones i were thinking of are raceland NOT hot tuning as i thought.steve_k wrote:Any links??reggid wrote:i know some pretty high powered m20 engines with a hot tuning manifold. it may not look as pretty but it still seems to perform well
steve_k
Now that's what you call an m20
So what's 259kw in BHP?
& that sound, oh man that sound,
