water in drivers footwell
adamh325
Post Sun Jan 26, 2014 12:43 am
:( any idea where the water could be entering the vehicle, also which drain hole should i check, pics would help.
Thanks in advance
Fastroad
Post Sun Jan 26, 2014 7:58 am
Also check its not a leaking heater matrix.
Is it the whole footwell or in the corners?
adamh325
Post Sun Jan 26, 2014 8:51 am
It's not the matrix as havnt used the car, seems to be more wetter under pedals
powelly
Post Sun Jan 26, 2014 9:25 am
Check the rubber grommet around the centre wiper spindle, it's most likely perished or maybe not even there, I've cured a few leaks now with this problem.
Image Le Mans Classic 2006
adamh325
Post Sun Jan 26, 2014 10:02 am
powelly wrote:Check the rubber grommet around the centre wiper spindle, it's most likely perished or maybe not even there, I've cured a few leaks now with this problem.
ill check that cheers, also can anyone tell me where are all the drain holes that would need to be cleaned and the best way in which to do this.
DHFiS
Post Sun Jan 26, 2014 12:19 pm
Check the 'elephants trunk' is clear
http://i44.photobucket.com/albums/f14/I ... Trunk1.jpg
adamh325
Post Sun Jan 26, 2014 6:21 pm
DHFiS wrote:Check the 'elephants trunk' is clear
how ?, does it come apart
