m20 gearbox on an m40?
ross_jsy
Will the above combination fit?
age
- Formerly twist316
yes it will fit but will sit at an angle, the same fitting an m20 box on an m52.
you will need to use the prop from the m20 though as the prop is a different length cira 100mm or something like that.
M40 rightness if you can get to 6000rpm noone can hear your tappets
ross_jsy
m40 prop? Not the m20 one?
Would be going into an auto if that makes any difference (not mine, I would leave the box attached to a decent engine!)
age
- Formerly twist316
sorry got that backwards, (edited to stop confusion in future)
the m20 prop is what you need.
ah, i thought it was a manual,
but i'm sure the same applies, check the gear ratios though to be sure they are suitable, i presume they are
