Will this bulb fit for the rear lights?
German-Whips
Post Tue Jan 21, 2014 8:14 am
My rear bulb which illuminates when the headlights are switched on has blown, and I was wondering whether this bulb will fit?
http://www.halfords.com/webapp/wcs/stor ... yId_165538
It says on the Wiki that the rear bulb should be a 12V 10W, so will this do the job?
Post Tue Jan 21, 2014 9:23 am
That's the correct tail lamp bulb. They tend to need replacing long before they actually blow because of the build up of a black coating on the inside of the glass, which can eventually reduce the light output to the point where you can barely see it's on.
