Mot
guss
I need it doing soon but I know the gator on the steering rack has a split,would this mean a fail? Ta
Yes. However, you may be able to temporarily repair it using black silicone sealant, if it's just a small split.
Obviously, clean the area using meths or white spirit before applying sealant.
guss
A thousand thank youz
Rtaylor2208
As above yes its a MOT failure.
Replacing it is a 10 minute job, disconnect the track rod end from the wishbone, slide off the old boot, sild on the new one and reconnect the track rod end. Obviously make sure its clamped at either end with eny fixings that came with the new one or even cable ties.
G-Bear
I picked up Lemforder boots from GSF i think for about £4 a side.. the came with fixings..Rtaylor2208 wrote:As above yes its a MOT failure.
G-Bear
jmc330i
I have in the past wrapped a boot with black insulation tape to hide a split. Not sure it would get through now but it was good enough at the time.Speedtouch wrote:Yes. However, you may be able to temporarily repair it using black silicone sealant, if it's just a small split.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
