Solid engine mounts
Hedley48
Post Sun Dec 22, 2013 11:59 pm
Seen some solid engine mounts as an upgrade to the soft rubber standard ones but they do have a bush in them just wondering how it would feel if I made some purely out of metal and is it even worth upgrading
DaveyB
Post Mon Dec 23, 2013 12:08 am
No bush. Metal to metal. Harsh ride unless you thrash your car daily then you wont notice. But daily driving makes for higher ammounts of vibration
Wanted Nothing atm :)!
Post Mon Dec 23, 2013 12:09 am
Puts increased stresses on mountings/welds etc and will 9 times out of 10 result in cracks appearing
Post Mon Dec 23, 2013 12:03 pm
In what way would that be an 'upgrade'? What's the problem with the standard mounts?
Solid mounts are (real) competition only, where the chassis and everything else is inspected for cracks and damage thoroughly, on a daily basis.
Black_Potato
Post Mon Dec 23, 2013 11:25 pm
These people do about the best compromise between road and track from my experience and they are what I run on my race car.
http://www.vibra-technics.co.uk/bmw/e30 ... _and_320is
3x S14 Rightness....
Hedley48
Post Tue Dec 24, 2013 2:33 pm
I do thrash it but it is my daily so will probably just use the standard ones then it's just the engines out and one of the mounts snapped so need replacing anyway , cheers
Post Tue Dec 24, 2013 6:53 pm
Copied from another post of mine yesterday.
http://2009.bmwfans.info/parts/catalog/ ... on_damper/
Part #12 missing from your mounts.
Use these with the standard mounts.
Andyboy
Alpina Colada
Post Tue Dec 24, 2013 7:52 pm
I love these uprated parts, especially compared with the worn out 23 year old originals.
Morat
Post Tue Dec 24, 2013 10:26 pm
I see what you did there :)
Post Wed Dec 25, 2013 9:14 am
what did he do?
zd3bx
Post Wed Dec 25, 2013 12:52 pm
Talking about engine mounts, is it worth replacing the original mounts with new ones, since I'll be replacing the sump gasket soon and will most likely have to drop the front frame...
Post Wed Dec 25, 2013 3:51 pm
Depends on their condition, but you can be certain that new ones are going to be firmer than twenty five year old ones.
Andyboy
Alpina Colada
Post Thu Dec 26, 2013 10:56 am
Rear beam bushes are another. 'Poly bushes are much better than standard ones. I replaced my 11 year old ones with poly and the rear axle isn't trying to fall out anymore'.
suchy
True Zone Relic
Post Thu Dec 26, 2013 12:14 pm
Andyboy wrote:Rear beam bushes are another. 'Poly bushes are much better than standard ones. I replaced my 11 year old ones with poly and the rear axle isn't trying to fall out anymore'.
Same with shagged out suspension vs. eBay coiloverz, "my £50 coilz are mint- my ride now handles way better than standard fitment BM shit"
