LSD Question
turkeysneck
Is it possible to swap the crown wheel and pinion from and open diff to a Limited slip diff.
appletree
Yes but you will have to get the mash and back lash set up again with shims
turkeysneck
Of course, I just want to know if the components are able to be swapped over.
Silverfang
Whilst you're at it, it'd be a good idea to check the plates on the diff itself, maybe even changing the ramps out for something more aggressive for better lockup
BMW and Opel, both RWD, both german, both good fun
http://www.clockservicing.co.uk/ For any clock repairs try here.
