Thanks for the votes guys.
Pete, here goes. Though I didn't want to waste server space putting up rust pictures again.
Surface rust, inner left rear of the roof. The outer side is mostly clean. So this must be where the rusted sunroof tray was touching.
Most of the rust was here, the tray and sliding mechanism:
The sunroof area needs to be patched, er, a bit
Maybe, I should fix the roof metal, put a toughened glass piece (dark grey colour?) cut to that size and have it sealed permanently.
It's Mumbai, what was the earlier owner thinking? Doubt I will switch off the AC and let dust and 37 degrees C come in willingly.
The guy who is going to make the new roof lining can make a manual slider to shut from inside. Or maybe not. Can just have a permanent glass sunroof. Because it's permanently sunny out here.
So how much does the entire thing weigh? 15 kilos? I can junk the metal sunroof piece, junk the inner tray, motor, and all. Seal the water outlet tubes inside.
Maneesh
1986 E30 M10 316 Manual Schwarz Chromie
1982 E28 M20 520i Henna Rot - Project
1988 E32 M70 750iL Schwarz - MASSIVE Project
1991 W201 190e Automatic Schwarz - Sold
1991 W201 190e Automatic Silver AMG Tribute - Sold
1993 E36 M40 316i Manual Brillantrot (RIP: rotting in peace)
Join other Carb Fanatics: E30 316 Carb - The Faithfuls
https://www.facebook.com/groups/444263742439145/
