tech 2 clips
ozzy2006
Post Wed Sep 18, 2013 1:52 pm
Hi all
trying to fix an mtech 2 kit from a coupe onto my convertible and having an issue with the clips as the pod clips not popping into the holes on the door. clearly im doing something wrong or missing some parts. could anyone give some advice on how or what they did to make the kit fit. I have read the wiki but could not find a solution..
thanks
Ozzy
ozzy2006
Post Wed Sep 18, 2013 2:16 pm
just had a quick word with shaz has brought to my attention i need grommits for the kit to fit in. as kit is going onto a car that has not had the kit on before.
are there any other clips or parts i may need in this case.
thanks
Ozzy
ross_jsy
Post Wed Sep 18, 2013 4:59 pm
I believe you can buy an entire clip and grommet kit from bmw.
Are you aware the side skirts won't fit?
ozzy2006
Post Wed Sep 18, 2013 5:01 pm
I done a bit of research and the conclusion is some modification is required
tonybtonyb
Post Thu Sep 19, 2013 10:46 pm
Main dealer for the clips. winkeye
tonybtonyb
Post Thu Sep 19, 2013 11:01 pm
