Radiator
pony
- I have been misbehaving and am sorry !
BMW Dealer which is where I got mine from
I think the 325s came in 2 different sizes. Depending on the year of production.
Alternatively go to Euro Car parts I think Behr are the OEM manufacturer but not sure.
Grrrmachine
- E30 Zone Wiki / Team Member
Nissens is a decent brand.
Realoem lists 3 types.
A standard one of 440mm width
A hot climate one of 550mm
And an A/C one which isn't listed.
So yes, it would stand to reason that yours is 440mm width.
P.S, I figured your car was a touring due to the build date.
A/C one is the same width as a standard one at 440mm but is deeper buy about 4 or so inches.capnmchl wrote:Realoem lists 3 types.
Just put a Nissens radiator in my 318iS and it works very well indeed. eBay was the cheapest by far, even though I had to wait a week to have it shipped from Denmark as it was apparently a rare one...
I ordered an EIS radiator from ECP and as well as being the wrong size it also leaked, and they were very reluctant to take it back and give a refund.
Nissens it is then.
Although i am pretty sure the radiator needs replacement the car has developed a weird issue. Where as before it would over heat slightly when in traffic and on a spirited blast, i went to drive it the other day now i find it takes for ever for itself to warm up. It will eventually go over the blue part of the temp gauge and stay there until around 20 mins of driving then starts to climb gradually to optimum temp, by which time iv finished my journey usually.
Along with this i noticed the idle of the car from especially a cold start is higher then normal and doesn't come back down . Although this is intermittent and sometimes it idles perfectly from the turn of the key.
My thoughts are from a little research coolant temp sensor or thermostat itself,
Parts that have been replaced recently are
Viscous (Behr)
Water pump
Thermostat although around 2 years ago now.
And radiator flushed and bled numerous times.
Any thoughts guys would be much appreciated.
Viscous (Behr)
Water pump
- **BANNED**
I would suspect the thermostat is stuck open,hence the slow warm up.
Buggered blue temp sensor usually gives over-rich running when warm,it's easy to check,take a resistance reading when cold,and again when hot.Best to take the reading at the ECU plug as well,to eliminate a wiring fault.
The ohm reading should be significantly different when comparing hot to cold!
Youth is wasted on the young.
Ecp and similar sites can't cope with late cabs or tourings as their system assumes your car will be e36 based. Other members have had similar problems with exhausts.
You're best of manually choosing the make and model and putting 1990 as the year. You should get parts which actually fit an e30 then.
cheers,
harry
harry
