URGENT: 320i to 325i alternator interchangeability
Nick91
Sat Aug 24, 2013 2:55 pm
Hey guys!
After a 4500 mile trip in my 325i down to Sicily and back, the generator decided to let go on the german autobahn, which has left me stranded just 300 miles from home, causing all instruments and lights to fail except the speedo and moments later the engine died.
I happen to have a 320i standing in my driveway back home, and I was wondering if the alternator from that will fit and work in my 325i that normally has the 90A one?
Thank you!
jmc330i
Sat Aug 24, 2013 3:06 pm
Should fit and work fine.
James
'91 325i Sport
'93 318i touring 16v
Nick91
Sat Aug 24, 2013 3:23 pm
Thank you jmc330i! Can anyone else confirm this before I have family members get on the train down here?
Thanks again, it's much appreciated :)
Sat Aug 24, 2013 4:08 pm
The early 320i had a 65 Amp alternator, but it should work OK on a 325i, at least temporarily until you can fit new brushes in your original.
**BANNED**
Sat Aug 24, 2013 4:14 pm
Be aware that some M20 alternators are mounted via rubber bushes,this type require a seperate earth lead to the engine mount.
Other than this,your spare alternator should work just fine.
Youth is wasted on the young.
Nick91
Sat Aug 24, 2013 4:33 pm
It's a late 320i 4 door, so hopefully it'll suffice for limping home to Denmark. Thanks Maurice!
Speedtouch wrote:The early 320i had a 65 Amp alternator, but it should work OK on a 325i, at least temporarily until you can fit new brushes in your original.
Sat Aug 24, 2013 4:36 pm
In that case, it should be an identical 90A one to your 325i one.
