Vibration damper for prop! Any one help?
matt_1234
Post Tue Aug 20, 2013 8:33 pm
Currently restoring a 1988 325i cab. Having bother with a part I need. Can any one help?
It's a propshaft vibration damper part number 23131222514.
rich318i
Post Tue Aug 20, 2013 8:38 pm
check eurocar parts
maggspower
Turbo Farmer Tractor Driver
Post Tue Aug 20, 2013 8:50 pm
I expect I have one that I could sell you.
This part is not needed though, and often removed. I have removed it on numerous cars without issue.
matt_1234
Post Tue Aug 20, 2013 8:57 pm
Priced it with BMW £245 mad prices. Much would u sell me one for? Or u think I could do away with it?
Thanks mate
matt_1234
Post Tue Aug 20, 2013 8:59 pm
Does the rubber donut still stay if the vibration damper is removed?
Post Tue Aug 20, 2013 9:04 pm
Common practice is to delete the 'damper' to no ill effect. Standard doughnut as per usual BUT be careful if buying a new one as some of the aftermarket ones are CRAP (Q DRIVE, yes we are talking about you !) Also be sure to fit it the RIGHT way, many do not and wonder why it disintegrates in weeks/ months :(
jimbom30cab
Tech 1 freak
Post Tue Aug 20, 2013 9:05 pm
YES you need it !!
the prop fixes to the donut and the donut then fixes to the gearbox flange
look at realoem.com drawings mate, that will show you how it all connects together
maggspower
Post Tue Aug 20, 2013 9:08 pm
matt_1234 wrote:Does the rubber donut still stay if the vibration damper is removed?
Yes.
The story is, the material that the original rubber "guibo" was made out of caused vibrations. This rubber has now been changed and no longer results in vibrations. There for the damper can be junked.
This is the story from Brianmooore, he is a well respected member and mod on here.
Like I have said I remove the damper with no ill effects.
Post Tue Aug 20, 2013 9:12 pm
The only cars I 'fit' the dampers to are quattroportes, usually placed carefully on the (soaking wet ) indigo rear bench for their final voyage :D
matt_1234
Post Tue Aug 20, 2013 9:19 pm
Cheers this was a great help. Much appreciated
Post Wed Aug 21, 2013 7:05 am
Removed the damper on my current and previous E30's - no ill effects.
