I found a very good link in the Wiki regarding the head but nothing on the block?
Anyone know of a good thread or a link to rebuilding the bottom end?
No problem, heared good things about corrys, so you should be in good hands there.SilverShadow wrote:Cheers Maggs for the reply however I already 27 spec engine, a couple of years ago it started blowing blue smoke so I have decided to rebuild it. I'm getting the following work done on the head by Corry's:
Pressure test
Acid dipped
Stem seals
Exhaust guides
Lap valves
Skim
I just wanted to know what work should I take on the block? rings anything else?
I don't want to change any of the core components e.g cam, crack etc just the rebuild part if that makes sense?
they did exactly the same to my m30 head, came back looking like new, they also changed any "suspect" rocker arms. how they know they are "suspect" I don't know.heared good things about corrys
