http://www.ebay.co.uk/itm/Steering-Coup ... 4608a88100
cheers guys
is this the correct rubber guibo
- **BANNED**
If you intend to fit it to the steering shaft,yes.
If you intend to fit it to the propshaft,no.
Youth is wasted on the young.
BMW_E30vert
Just get a good second hand one of here less messing about also check battery to see if its leaking acid had the same happen to my car due to a leaky battery
That one isn't significantly cheaper than the real item from BMW (unless the price has recently increased a lot), and you'll still need the four special bolts to fit it, if your existing guibo is the original riveted one.
